Machine Vision
Image Acquisition Times
Everyone,
I am new to machine vision and I had some questions as to what I should expect from my vision system in regards to speed and acquisition time.  I can start by describing the system I am using.
I have VBAI 2010 for software
The program runs on x64 windows 7 computer with 8 gigs of ram
I have 2 types of cameras on the line, Basler Ace 2500 14gc and Basler Ace 1300 30gc.
The cameras run to a Ethernet switch and then from the Ethernet switch they go to the GigE NIC of the PC.
I use a PC based control software to send triggers through modbus to VBAI 2010
So, for me to send a trigger to VBAI through Modbus, and to receive data back from VBAI after the inspection is complete is taking me around, 500 msec.
So what happens in these steps,
I send the trigger, which initializes the inspection.  The inspection starts out with an acquire image(Basler Ace 1300 30gc, set to Mono8/Set to single frame/snapshot).  I find an edge, then set a coordinate system, then find another edge and I use the y pixels from this edge in a calculator step.  The calculator step just is a multiplication step to change pixels to thousandths of an inch.  I then send this calculator number back through modbus to the PC control software.
This whole process takes around 500ms.
So what I am wondering is if this seems like an appropriate time?  I have done research on line about acquisition speeds and from what I read I feel like this is a slow time.  Does anyone have any pointers for me or things to attack to help reduce cycle time.  I am getting push back to try and reduce the cycle time by 200 msec and I don't know if this is a realistic goal or not.
Also with the Basler Ace 2500 14gc I am seeing times in the 1 second range for similar inspection steps(really only an acquire image,detect object, calculator step).  Now I do understand that this camera will be slower due to the reduced framerate but I am also looking to cut the fat out of these inspections as well.
All help is appreciated.
Thanks for your time
(3,350 Views)
Don't use the snap shot mode for acquisition. Read me the context help for the step to understand difference between immediate and wait for next. Hope this helps. Brad
(3,348 Views)
Context states the following
Wait for Nect Image - Waits for the next available image before transferring an image
Immediate - Immediately transfers the current image if it is newer than the image that was last acquired
(3,343 Views)
