Machine Vision
IVA Load Localized Strings.vi
Software: Labview 8.5 and NI Vision Assistant 8.5
When I Try to open any VI in folder Vision Assistant 8.5\solutions, LabVIEW tells me that it can not find "IVA Load Localized Strings.VI"
Where can I find it?
(3,885 Views)
These VIs are not example VIs. Sorry for the confusion. They are part of the software and are basically used to enumerate the solutions in the Solutions Wizard dialog when you invoke it.
If you want to see how the solutions is implemented in LabVIEW, select a solution from the Solutions Wizard, then use Vision Assistant to create the corresponding LabVIEW VI (Tools>>Create LabVIEW VI...)
-Christophe
(3,879 Views)
Christophe, thank you for your help. Smiley Very Happy
(3,870 Views)
