Machine Vision
IP camera interface with MAX
How to detect wireless IP cam with Max please help.... :) Thanks, Gagandeep.
Gagandeep sharma
(4,485 Views)
IP cameras are not suported by IMAQ or IMAQdx, so they will not show up in MAX.
If you need a work-around, you can check out roborealm and the Virtual Camera add-on.  If your WiFi IP camera is supported by RoboRealm, you can activate the Virtual Camera Driver, and this virtual camera will show up in MAX.  You will need to have the RoboRealm application running in the background.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,287 Views)
Basler and Axis IP cameras _are_ supported by IMAQdx and will show up automatically if detected on the local subnet.
Eric
(4,283 Views)
I have a ip cam GBC that is not supported by MAX.
how can I get it to communicate with labview?
please help
(3,698 Views)
