Machine Vision
IMAQdx
I am a beginner in labview. i have been trying to make a VI that captures an image at a time using imaqdx.snap. but it gives a black(blank) image in return. i checked the camera result using NI MAX , where snap fuction gives black image in display but grab function works perfectly fine. I have already tried unistalling vision acquisition software and reinstalling it.
need help urgently Smiley Sad
Message 1 of 10
(6,600 Views)
Fary,
What type of camera are you using? Knowing the manufacturer, model and bus type would be very helpful.
Message 2 of 10
(6,580 Views)
i am using interated hd webcam( of my laptop dell latitude E6410)
Message 3 of 10
(6,574 Views)
BUS TYPE : DIRECT SHOW
Message 4 of 10
(6,571 Views)
Does the webcam work correctly with other software? Skype for example?
Message 5 of 10
(6,548 Views)
yes , it works perfectly fine with skype and other camera softwares
Message 6 of 10
(6,540 Views)
It would help if you could try the code in the following example: https://decibel.ni.com/content/docs/DOC-3587
I'm curious to see if the first frame of the resulting .avi is blank.
Message 7 of 10
(6,513 Views)
the item does not exists. it may have been deleted Smiley Indifferent
Message 8 of 10
(6,477 Views)
But I guess I problem is with the system I am using. Because I have windows 8 and the laptop is not compatible with win 8. And people having it runnig it on windows xp, have their snap function working perfectly fine. And drivers of this system for windows 8 are not available.
Message 9 of 10
(6,476 Views)
Fary
Link must be bad. Try this one instead: https://decibel.ni.com/content/docs/DOC-3587
Message 10 of 10
(6,455 Views)
