Machine Vision
IMAQdx example doesn't work properly
I use Sony XCD-SX900 fire-wire ccd camera with LV8.2 and IMAQdx 3.0.1. It can grab images well in MAX. But when I used grab.vi in IMAQdx Example.llb, everytime after I stopped the vi (clicking the stop button), I had to close MAX and reopen MAX again, otherwise one error window would appear: "Error-1074360305 occurred at an unidentified location. Possible reason(s): NI-IMAQdx:(HEX oxBFF6900F) Attribute not supported by the camera."
What the possible reasons? Thanks  a lot!
Brs,
George
(3,759 Views)
U cant use max and ur grab window simultaneously.Is that the reason?
(3,593 Views)
Hi, George,
I've got exactly the same trouble with Basler camera. "Attribute not supported..." error returned when I attempt to start grab images in LabVIEW. But! This error occured only in development environment, so if you will build the executable, then probably you will not get this error.
Sympthoms are:
- camera working in MAX without troubles
- it works in CVI without troubles as well
- builded LabVIEW executable also working
- it doesn't work in LabVIEW development env.
Try to build the executable, and check that application working.
Andrey.
(3,586 Views)
