Machine Vision
IMAQ went missing
After installing Vision Development Module 2011, and later Vision Acaquisition Software 2010, all the NI IMAQ VIs went missing, the MAX shows the IMAQdx is installed but its not showing up in labview. I tried to repair the VDM and acquisition software but doesn't help, can someone please help please?
Thanks.
(4,172 Views)
Do you have the "Vision and Motion" palette at all?  I'm also wondering if MAX shows NI-IMAQ to be installed as well as IMAQdx.
(4,159 Views)
yes I have Vision and Motion palette, and ya Max shows NI-IMAQ and IMAQdx installed.
I wanted to work with video acquisition, but the vis seem to be missing, there is no IMAQdx in labview.
(4,155 Views)
(4,155 Views)
Try installing the new update here. There have been some similar problems reported when using the older version of the drivers. See if that makes your palette show up.
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(4,143 Views)
