Machine Vision
IMAQ vision error: Unable to read data
Hello
I had tried to make a vi to read characters from an image but IMAQ OCR read file is showing error.please help me to come out from this error
i have attatched the vi and the image which i am using to read the characters
(4,119 Views)
What character set are you using?  You need to create one if you haven't.  OCR is basically a form of pattern match.  Here is thread describing how to do this:  http://forums.ni.com/t5/LabVIEW/how-to-create-character-set-file/td-p/1130815
Have you seen the OCR examples in the NI Example Finder?  Go to Help>>Find Examples... and then type in "OCR" in the search.
(3,976 Views)
