12-07-2011 08:49 AM
Hi
i use the function IMAQ optical FLOW (LKP) but the only way to see the output of this funcion (motion of objectes) es call IMAQ Overlay Motion Vector to paint the result as a overlay on the image i need to used these data on my calculation but i can´t use it first there is no output from motion funcions , seconde i dont i ahve a funciones that convert the overlay image as a data (points ,lines , rectangle, arc,...etc) i can save the image with overlaydata and readit but i cannt use it.
1- i need output from the motion funciones
2- funciones that conevrt the overlay image to data as point , lines, rectangles... etc.
04-06-2013 10:50 PM
You are using LKP right? as far asI understood, the data was given in points, so there is an output, the distance array and the points out.
