I'm developing a confocal microscope with multi-axis control where I
use servos and motion controller cards for the works. I managed to
generate vivid images of semiconductor images in 2D plane (x,y) from a
Laser Diode source reflectance and optical feedback, but would like to
make slices along z-axis so that I would have completely define a
stacked image i.e. I= f(x,y,z) (hences, a 3D reconstruction from 2D
planes) in this manner I need to displace a z-motor from a range (+),
zero, to (-)in each displacement I would have then generated a 2D
image save and kept into a file. I have a problem with IMAQ VIs on how
to do this exactly when I need to repeat the steps and file saving to
a disk? Any suggestions or ideas are welcome.
