Machine Vision
IMAQ multi camera acquisition
I use IMAQ 1410 board. 1410 board has four camera channel.
I operate IMAQ 1410 board with Visual C++ 6.0.
So, with C code, I want to acquire camera image data from each channel.
For example, if I want acquire image data from  second channel, I want to acquire second channel image only.
I tried to acquire multi-camera image several times and different ways,
but I could get only one channel (default channel) image.
I couldn't get second channel image.
Some people suggest to use C code as follows.
 for (i = 0; i < NUM_RING_BUFFERS; i++)
  errChk(imgCreateBuffer(Sid, FALSE, bufferSize, &buffers[i]));
  errChk(imgSetBufferElement(Bid, i, IMG_BUFF_ADDRESS, (uInt32)buffers[i]));
  errChk(imgSetBufferElement(Bid, i, IMG_BUFF_SIZE, bufferSize));
  bufferCommand = (i == (NUM_RING_BUFFERS - 1)) ? IMG_CMD_LOOP : IMG_CMD_NEXT;
  errChk(imgSetBufferElement(Bid, i, IMG_BUFF_COMMAND, bufferCommand));
  errChk(imgSetBufferElement(Bid, i, IMG_BUFF_CHANNEL, i));
However, it couldn't get image data from specific channel that I want to acquire.
I coded programs like this which doesn't work:
 errChk(imgMemLock(Bid));
 errChk(imgSessionConfigure(Sid, Bid));
errChk(imgSessionExamineBuffer(Sid, bufferIndex, &lastAcquiredBuffer, &bufferAddress));
errChk(imgSessionReleaseBuffer(Sid));
Pleas tell me C code programs to acquire image data for not only default channel but other channels.
I really need this code deperately.
(3,527 Views)
You want to use labview and through which call ur c libs?
(3,517 Views)
I know that labview program has several labview example related to multi camera acquisition.
But, I have to use only ansi C code right now, it's long story.
"which call ur c libs?"
I don't understand your question
I use C code from Ansi C example of NI, LL Ring.
(3,513 Views)
