Machine Vision
IMAQ and Lab View version compatibility
I had an application running with LV 7.1 and a version of IMAQ that escapes me. However, in a frenzy to do something else, software versions were reloaded and has generated an incompatibility in that my original software is now malfunctioing. The malfunction is with just LV 7.1 installed (no IMAQ addition installed) the VI "IMAQ ArrayToImage" and "IMAQ Write to TIFF" are not present. However, when I install Advanced IMAQ 6.01, I get them both but lose the functionality of IMAQ Image Cluster to Image Datatype and vice versa. The puzzle is that the VI's all worked at one point for a combination of LV 7.1 and one IMAQ version (6.01, 5.0, 2.21, or IMAQ Vision builder). I'm hoping to get some insight regarding software compatibility and functionality.
Best,
Mike Reilly
(3,345 Views)
Mike,
Can you post a small hunk of your code?  I could check it using LV 7.1 and Vision Builder 7.1.  I do not have the older versions of Vision but at least I cna tell you if it is broke using these versions of software.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,339 Views)
