‎02-20-2006 07:07 AM
‎02-20-2006 10:18 AM
‎02-20-2006 11:26 AM
IMAQ Vision 7.1.1" expand "LabVIEW Support") it says that there is a more up to date version already installed (odd seeing as it is the same CD as before). Then when I try to run VisUtil.exe given in the KB article it tells me that Vision support for Labview 8 is required (and gives me instructions which are identical to the ones in the KB aticle to add it - obviously I get the same 'already installed' response).‎02-20-2006 11:35 AM
‎02-20-2006 11:44 AM
‎02-23-2006 09:07 AM
‎02-23-2006 05:04 PM
Greg,
You mentioned that you were installing NI-IMAQ 3.5 and ThSA replied that NI-IMAQ 3.5.1 supports LV8. Are you installing NI-IMAQ 3.5 or 3.5.1?
Ryan F.
‎02-23-2006 07:07 PM
‎02-24-2006
09:21 AM
- last edited on
‎07-09-2025
02:47 PM
by
Content Cleaner
Hey Greg,
Looking at your problem again, it seems to be limited to an incompatibility with Vision 7.1.1 and LV8. The fact that you have image acquisition functionality narrows it down to a problem Vision and your NI-IMAQ should be fine. If you would still like to get the newest version of NI-IMAQ, it can be downloaded and used freely.
http://digital.ni.com/softlib.nsf/websearch/34E35376A052690E862570F9005349A3?opendocument&node=132060_US
As to the Vision 7.1.1 incompatibility with LV8, I found the following thread and possible workaround. This issue seems to exhibit the behavior you are seeing and is linked to an invalid installer directory.
https://forums.ni.com/t5/LabVIEW/LV-8-und-Vision-7-1-1/m-p/288589?requireLogin=False
workaraound: Manually copy all files in C:\Program Files\National Instruments\LabVIEW 8.0\menus\default\vision to C:\Program Files\National Instruments\LabVIEW 8.0\menus\Categories\VisionMotion and move VisionControlsMNU.DLL and VisionControls.mnu to C:\Program Files\National Instruments\LabVIEW 8.0\menus\Controls.
Let me know if this applies and helps fix your issue.
Ryan F.
‎02-24-2006 01:04 PM
