I've installed LabView 7.0, and in the toolbox in vision i can't find the IMAQ WindClose.vi and IMAQ WindDraw.vi, i really need with urgent, please i need to find this vi's
These VIs will be installed only when you have the IMAQ Vision Development Module installed (not just with NI-IMAQ). If they are not present in your palettes, then I would verify the installation and/or re-install the IMAQ Vision software. When you install it, you must make sure that support for the LabVIEW version you are using is checked.
