Machine Vision
IMAQ Boot Error Entry Point Bit Found
I am getting the same error described here:
http://digital.ni.com/public.nsf/allkb/BFFE6F5E691190FA8625743B003CC0F8
That is IMAQBoot.exe Error - Entry Point Not Found.  My Framegrabber (PCI1422) is attached to the computer but through a Magma PCI to Cardbus interface to a laptop computer.  The laptop runs Windows XP and in the device manager I can see the IMAQ board with no apparent problems.  I can run sample programs that use IMAQ.lib but if I run IMAQBoot.exe manually or at bootup I get this error.
(3,278 Views)
Hello jobermark,
When do you get this error apart from at booting of the PC? What version of NI-IMAQ do you have? Has any change in your software/hardware configuration resulted in this error? This would give me a better idea of your problem.
I would try repairing the NI-IMAQ driver on your PC. If this does not solve the problem, you could try uninstalling and re-installing the driver. Please post again if this does not work.
Vivek Nath
Machine Vision
(3,258 Views)
