Machine Vision
I have done a calibration to change from pixels to mm however result is in pix
In Vision Builder 3.0 AI I have run a calibration on a known standard to convert from pixels to mm however my results are still displaying in pixels and I cannot find an option to change units to mm.
John
Jonathan
(3,519 Views)
It should be pretty straight forward. Attached is an example of what you're talking about. It should do all of the conversions for you automatically. Once you've calibrated your image to mm, that should be the standard for the following steps.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,514 Views)
