Machine Vision
I have a logitech quickcam express, I need labview to extract information from the web camera. How do I do this? Can this be done using the IMAQ functionality? Need urgent help!
Chris,
There is a Video for Windows driver that some people have had success with. It is available in the info-LabVIEW archives. I think you can get there from www.brianrenken.com.
Bruce
Bruce Ammons
Ammons Engineering
Message 2 of 11
(13,935 Views)
Chris -
Here are two more sources for extracting image information from a web camera in LabVIEW. The attached .zip file contains a LabVIEW VFW VI. The Readme file describes how to use it (I believe this is the same one from the info-LabVIEW archive). Also, you can visit http://inventeering.com and demo their version of a LabVIEW VFW VI.
Jack Arnold
Application Engineeer
Message 3 of 11
(13,935 Views)
Thanks a million Jarnold, those VI's have come in really handy. Thanks again.
Cheers
Chris.
Message 4 of 11
(13,935 Views)
Check out the ActiveX Control with LabVIEW examples at www.inventeering.com It is called INVENTvisionVFW
Message 5 of 11
(13,935 Views)
Dear Sir,
I have downloaded the zip file put by you. I would like to know from you how do I use it for acquiring the image directly from the USB port using a webcam.
It would be nice if I could get a reply fast.
Message 6 of 11
(13,935 Views)
Hi Jack
the labview.vfw work fine in my pc, i am able to capture the real-time image. but currently i have a problem, i need to web enable the program. I was able to monitor the front panel in another pc but the real-time image (video window) does not appear on this pc, it only appear in the server pc. why?
Message 7 of 11
(13,935 Views)
hi...
i just download the zip file. just plug in your web cam to the usb port with the driver and run the main vi, and it works...
hopes it helps
Message 8 of 11
(13,935 Views)
Quite an old thread.
Is this method still in use? Or that IMAQ for USB surpasses all of its abilities? I just had a look at the link given by Jack, and found it interesting. Hence kudos. 🙂
Vaibhav
Message 9 of 11
(9,762 Views)
The IMAQdx drivers now include USB cameras and can do much more than the old methods, I think.  I would think it would be better to invest in IMAQdx instead of trying to jump through hoops with an older method.
Bruce
Bruce Ammons
Ammons Engineering
Message 10 of 11
(9,713 Views)
