Machine Vision
I can not find usb camera function in labview function pallete.why?
 Hi, I hve install labview 2009 and vision development module 2010 and vision acquisition software 2010. But I can find usb camera function in the function pallete. why?
Message 1 of 10
(8,482 Views)
Use IMAQdx functions for getting images from usb cam. Good idea to check acquisition in MAX (you camera should be listed in IMAQdx devices).
Andrey.
Message 2 of 10
(8,480 Views)
Hi, I want to access the NI-IMAQ for USB Cameras VIs from within LabVIEW, select NI Measurements»Vision»IMAQ USB from the Functions palette of your block diagram, as shown in Figure:
usb camera VIs
but I can't find IMAQ USB in my labview.why?
Message 3 of 10
(8,472 Views)
Again, NI-IMAQ for USB Cameras is not a part of VAS/VDM. This toolkit was intended for old LabVIEW/Vision versions. Right now acquisition from usb cameras is supported by IMAQdx:
Andrey.
Message 4 of 10
(8,465 Views)
I have a directShow usb camera,it can't be connected to labview8.6, but can be connected to labview7.1, why?
If i use labview2010, with NI -Imaqdx, can i connect the camera to labview 2010?   thanks!
Message 5 of 10
(8,102 Views)
Hi Andrey,
I am in a similar situation
I am also using the IMAQdx functions palette and still the Enumerate Cameras function doesn't list any camera.
Can you please check the thread and see if you have some clues?
Thanks ahead!
Vaibhav
Message 6 of 10
(7,913 Views)
Hi, Andrey!
I have installed LabVIEW 2010 and the NI-IMAQdx functions are just the same as the picture shown above.
Now, I have a problem. In old LabVIEW/Vision versions, I can use the IMAQ USB propertypage.vi to access the properties page that is provided by the camera manufactuter, how can do this with the functions in IMAQdx?
Message 7 of 10
(7,624 Views)
you have to use the IMAQdx property node, you will be able to find a lot of informations.
Message 8 of 10
(7,612 Views)
Hi~
Could you show me how, please?
Message 9 of 10
(7,602 Views)
Here you can find some informations about the camera and you are able to set attributes.
Message 10 of 10
(7,593 Views)
