Machine Vision
How to utilize Vision Module in Embedded System?
Hi all,
I have problem in my Vision system which i wanna develope using Labview- Blackfin BFxxx embedded module, but the trouble is i can not compile all functions in Vision modules that is only supported for Window OS. That's why i think i must write all codes in C. But my question is how can utilize Vision Development Module including Image Processing and Machine Vision functions to develop my system in Embedded Module faster rather than writting code in C language??? Every comments or suggestions are highly appreciated.
Thank all in advanced.
(3,390 Views)
Hello ALive,
The Vision Development Module includes a set of image processing functions that can be called from either LabVIEW or C. There should be no difference between using the LabVIEW embedded module or C to execute an image processing application.
I hope this helps.
Vivek Nath
Machine Vision
(3,374 Views)
Hi vivek,
               I think the user wants to implement the labVIEW function which is not supported by his processor.
(3,326 Views)
