Machine Vision
How to show color map or color bar with the image?
Dear Labview users,
I need help to show the colormap with my images in labview. Can anyone please help how to show colormap for example for rainbow palette. I have attached a small portion of my detector image.
nomi
(6,405 Views)
image.pngyour question is not so clear if you want just to show your grayscale image in  rainbow use above method that I show you in image
(6,372 Views)
Thank you for your effort. Please read again my question. I need to show colormap/color bar with my image. Colormap or colorbar is the bar mostly with all images to show the scale of pixel's intensities. Example is attached please.
(6,367 Views)
check this vi maybe it solve your problem
(6,353 Views)
Thank you indeed for the help. However, I am not able to open this 'vi' in my Labview 14.0. Can you please save as in some lower version of Labview, usually people save as in Labview 9.0.
kind regards,
(6,350 Views)
Accepted by topic author nomi_g
(6,344 Views)
Thank you indeed.
(6,336 Views)
