02-06-2009 01:40 PM
I am trying to find out how to set binning and exposure time. I use a PCI-1428 frame graber.
Thanks a lot,
Travis
02-06-2009 09:46 PM
This depends more on the camera than the framegrabber. What brand and model of camera are you using? The commands for setting these parameters are probably in the camera manual. You will need to send them to the camera using the serial connection. You can set these up using the camera file editor.
Bruce
02-08-2009 03:40 PM
Thanks. I am really new to all this.
The camera we are using is Imperx IPX-2M30-L. I just checked that I could set vertical binning by "svm b".
Could you give me some clue of how do I initiate the communication and send "svm b" over to the camera?
Thanks a lot,
Travis
02-09-2009 09:21 AM
You can use the camera file editor. It can be downloaded from the NI website. It will allow you to make changes to your MAX configuration file, including adding serial commands for camera control.
Bruce
