Machine Vision
How to send trigger to external devices using labview
Hello, I need help in sending a trigger to external device using labview.
I have mounted strain-gauges on the beam and using labview to continously recording the strain values. Now I want to send the trigger (ttl/make/break) to outside device as soon as strain values goes over certain limit. I am new not labview and mostly using express vi's. Also I can start the strain acquisition when strain value goes over certain mark. But I am not sure on how to send the trigger pulse to the external device using labview. I am attaching the pic of some of my efforts.
System Information: Labview 8.5.1, SC-2345 connector block, SCC-SG01 Strain module, PCI-6251 DAQ Card and SCC-DO01 Digital Output Module.
Sine
(3,354 Views)
Hi labview.edu:
I noticed that you have essentially (if not the exact same question) posted in at least three other threads:
http://forums.ni.com/ni/board/message?board.id=250&message.id=46618
http://forums.ni.com/ni/board/message?board.id=170&message.id=387573
http://forums.ni.com/ni/board/message?board.id=170&message.id=387709
Please take the time to identify the most relevant forum to make your post in and only create one thread for a question.  These forums are actively monitored to help make sure that you get your questions answered so please be patient for responses.
Alex Person
NI-RIO Product Support Engineer
(3,330 Views)
