Machine Vision
How to select one of the same name Cameras as using IMAQ USB toolkit
Hey Vision Man,
        I am using IMAQ USB toolkit to capture image from USB web camera,it works and nice, but I have two cameras, the same module, the same driver, I use "IMAQ USB Enumerate Cameras.vi" to obtain cameras names, it returns the same name, "IMAQ USB init.vi" is taking camera's name to create the reference, it means I can't select one of cameras.
how to solve this mess if I insist in using IMAQ USB driver and two of the same webcams? or, any the third software to change webcamera's names? thanks.
Message 1 of 9
(5,522 Views)
Hey NI Vision Engineer,
        Any helps? thanks.
Message 2 of 9
(5,504 Views)
Really no helps? I am so helpless with this situation.
Message 3 of 9
(5,468 Views)
Try to use Measurement and Automation Explorer to set different alias for different cameras.
Message 4 of 9
(5,442 Views)
Frankey
           Thanks for your reply, it gave me some hope, and I don't know how to set different alias for my USB camera with Measurement and Automation Explorer, Can you tell me how to use this function? BTW, the USB web camera is not NI's product, can Measurement and Automation Explorer help this also ? thanks to tell the handle.
Message 5 of 9
(5,421 Views)
does API(ur name) means windows library? if so have a look at my post(call library function node). you may help.
Message 6 of 9
(5,397 Views)
thanks lightgoal,
           No, that is not my problem, I mean, because I have two web cams, there are the same module, using the same driver, and "IMAQ USB Enumerate Camera.vi" returns two camera's name in 1D array, but their name is the same, so, how can I select camera at my pleasure?
Message 7 of 9
(5,379 Views)
well some while ago I was looking for a problem like this and I saw that ni had a page for this problem. if you haven't seen that It's a good idea to have a look at that. unfortunately I now don't have the link but I'm sure you can find it with a little search.
Message 8 of 9
(5,370 Views)
Hi, Lightgoal, thanks, I got the question, which is in your pose.
http://forums.ni.com/ni/board/message?board.id=200&message.id=21713&query.id=571517#M21713
and the other user has the same of my problem:
http://forums.ni.com/ni/board/message?board.id=200&message.id=20729&query.id=571517#M20729
and NI provides the document something like that problem solution answer:
http://digital.ni.com/public.nsf/allkb/F936725EE75F1E55862572D6006C9276?OpenDocument
Message 9 of 9
(5,344 Views)
