03-13-2003 02:32 AM
03-18-2003 11:24 AM
03-30-2018 04:32 AM
Sir I can't get the solution to find the spaces between the strings .. sir pls help me with that sir and if possible how can I contact you.
If I need a designed Vi of that I will send u sir..
04-04-2018 12:21 AM
Instead of reading just read string from the IMAQ OCR Read text 4 , read Character reports and use math algorithm to find the distance between charactes and provide an offset to define whether it is space.
Else while training Character set file fix minimum space distance as your requirement.
