Machine Vision
How to make pattern matching test more forgiving
   Hello, I'm trying to pattern match to letters on a VF backlit display.  Sometimes the letters are slightly dimmer or brighter than the learned .png template and the matchscore returns 0.   I just want to know that it's the correct letter and don't care much about the intensity of the letter.  The matching seems much too sensitive to intensity.   Here is a portion of VB6 code I am using with .png templates.  I don't know if the MatchOptions are setup the best for what I am trying to do.   I've tried adjusing the mincontrast and changed rotinvariant to shiftinvariant, with mixed results.  I don't know what matchfactor is for.  There might be more options I could use, but don't know about.
    MatchOptions.MatchFactor = 0
    MatchOptions.MatchMode = cwimaqMatchRotationInvariant
    MatchOptions.MinimumContrast = 30
    MatchOptions.MinimumMatchScore = 500
    MatchOptions.NumMatchesRequested = 1
    MatchOptions.RotationAngleRanges.Add 2
    MatchOptions.RotationAngleRanges(1).Min = -20
    MatchOptions.RotationAngleRanges(1).Max = 20
    MatchOptions.RotationAngleRanges(2).Min = 0
    MatchOptions.RotationAngleRanges(2).Max = 0
    MatchOptions.SubPixelAccuracy = 0
    SearchRect.Initialize X, Y, DX, DY
   'Draw Rectangle box for Searching
    frmMain.CWIMAQViewer1.Image.Overlays(1).DrawRectangle SearchRect, cwimaqOverlayModeFrame, vbYellow
  '  frmMain.CWIMAQViewer1.Refresh
    'Match Template to Image In Search Box
    frmMain.CWIMAQVision1.MatchPattern2 frmMain.CWIMAQViewer1.Image, frmMain.CWIMAQViewer2.Image, MatchOptions, Matchreport, SearchRect
(3,391 Views)
Hi Dan,
Match Factor appears to be the Match List Reduction Factor.
Stephen Meserve
(3,363 Views)
