Machine Vision
How to get pointer to image from VB CWIMAQImage structure to pass to 'C' DLL processing function?
I would like to call a DLL image processing function written in 'C' from VisualBasic. The function arguments are a pointer to the image data (unsigned char *) and the width and height of the image. How do I get a pointer from a variable declared as CWIMAQImage in my VisualBasic program?
Thank you.
(3,157 Views)
Why don't you use the function CWIMAQImage.ImageToArray which will give you a pixel array of the image and that you can use in VB or C. Call it like any other datatype, CWIMAQInage is a activeX control which would be hairy to pass around.
Hope it helps.
(3,157 Views)
