Machine Vision
How to get old VIs?
I have some old VIs for an Omega temperature sensor controller that were written for LabView 4.0.1. I have 8.5, and it isn't backwards-compatible enough to use these VIs. How can I incorporate them (or at least see them so I can port the code)? They're held in a .llb file.
(3,474 Views)
Best way is to redo the code if you have 4.0 on one system and 8.5 on another it will be easy.Else u have to have subsequent versions to build the code to 8.5.
If your code is not confidential then post it in the forum.We could convert it to 8.5
(3,469 Views)
here's the code - it's from omega systems.
(3,466 Views)
Hi Nasgul,
here is your code saved for LabVIEW 7.1.
You can open it now with 8.5
Hope it helps.
Mike
(3,444 Views)
worked from the word go. Thanks!
(3,419 Views)
