Machine Vision
How to fill hole effectively?
Hi everyone. I'm trying to do particle analysis. however, after thresholding, the particles got holes inside them. i've tried to use IMAQ FillHole befor morph, however, the image turns all black. i really hope that the holes can be filled, so that i can morph the particles without losing the information (if there is holes, we cannot apply morph too many times, else, we will lose the information). Thanks in advance! Regards.
(3,921 Views)
Most likely the Fill Holes routine converts the image to values of 0 and 1.  If you change the display palette to binary, the objects will be red.  Binary Morph will work fine on this image.
Bruce
Bruce Ammons
Ammons Engineering
(3,911 Views)
thanx for your reply. i already convert my image to binary using autoBthreshold, with method inter-class variance (otsu thesholding). you can see a simplified verssion of my program in the attachment. are they different from what you said?
thank you,
regards,
sam.
(3,894 Views)
sorry no attachment in prev reply. this is
(3,892 Views)
