01-25-2007 02:49 AM
01-25-2007 06:14 PM
Hi Jason,
If you want to convert an image to a canny edged image, then
yes, you are correct that using the IMAQ CannyEdgeDetection will suffice. This
function uses a specialized edge detection method to accurately estimate the
location of edges even under conditions of poor signal-to-noise ratios. I have attached a screenshot of my block
diagram which opens a jpg file, extracts a color pane, and performs a canny
edge detection. You can change the filter
settings depending on the desired resulting image. The CannyEdge Detection does return an image; if
you would like image data to be returned as an array (data point position
coordinates, contrast, polarity, etc.), I would suggest using the IMAQ Edge
tool which finds edges along a path defined in the image. Edges are determined
based on their contrast, slope, and steepness. There is a great example in
LabVIEW which utilizes this function titled Edge Detection Example which can be
found in the Example Finder using the task search under Toolkits and Modules
>> Vision >> Functions. I
hope this helps. Please let me know if
you would like further clarification or assistance.
Vu D
02-01-2007 06:36 AM
02-02-2007 03:49 PM
Hi Jason,
After taking a look at your images, there seems to be quite a bit of noise running horizontally across the images. These lines are pretty strong, which I assume is why you are not getting the desired results in your program. I would recommend trying to filter this noise somehow. If you can take two consecutive images while keeping your camera stationary, do these noisy lines shift? If so, an option we have would be to average the image information from both frames so that the features will be enhanced while diminishing the noise. You might also want to take a look at the different filtering options (smoothing, sharpening, etc). You can easily access these functions using Vision Assistant to quickly see how the various filters alter your image. Once you are able to suppress the horizontal noise, you can also try changing the various filter parameters of the Canny Edge Detection function. You might also want to check if you are able to get better results using a different color plane in the “ExtractSingleColorPlane” VI (right now it is set to “Luminance”). Hopefully this helps.Vu D05-02-2007 06:02 PM
I wonder if you have a screenshot the block diagram of the Canny Edge Detector developed manually (not using IMAQ)?
Thanks.
05-03-2007 02:56 AM
Hi Vudoo
Do You know if it is possible to implement the canny edge detection in VBAI?
Simon
