Machine Vision
How to convert 1d array containing RGB data into a 2d array to show with IMAQ display
Hi, I'd like to know if there is a way to convert my array into a 2d array in order to load it to a IMAQ display using ArrayToImage.
This is is how the data is arranged in the array
Element0 =R
Element1=G
Element2=B
Element3 =R
Element4=G
Element5=B
Element6 = R
Element7=G
Element8=B
Element N
The size of the array is = width * height * 3...
 I want to know if there is a way to convert this array to a 2d Array to use with imaq.
I can't figure out how to do it in labview, I did the same in VB 6.0, but I'm newbiee at LabVIEW...
This is the code I used in VB.
    bReval = StCam_TakePreviewSnapShot( m_hCamera, pbyteImageBuffer(0), dwBufferSize, dwNumberOfByteTrans, dwFrameNo, dwMilliseconds)
    ' m_hCamera = is the handler of the camera
    ' pbyteImageBuffer(0) = is the Buffer where the image is stored
    ' dwBufferSize = width * height * 3  = 1024 * 768 * 3
     'Then I convert the 1d buffer to a 2d array
        i = 0
        For k = 0 To 767
            For j = 0 To 1023
                myImageArray(j, k) = RGB(CInt(pbyteImageBuffer(i + 2)), CInt(pbyteImageBuffer(i + 1)), CInt(pbyteImageBuffer(i)))
                i = i + 3
            Next j
        Next k
    'And finally I create the image with the given 2d array
     frmMain.CWIMAQViewer1.Image.ArrayToImage myImageArray
Thanks.
Attatched is the vi I'm using, and also a picture of the vi.
 Gustavo Ramirez.
Test Equipment Sw Engineer,
Stoneridge Co.
(4,468 Views)
Hey,
Somthing like this should do it.
Good luck with it.
Let me know how you get on.
AdamB
Message Edited by AdamB on 11-10-2006 03:05 AM
Applications Engineering Team Leader | National Instruments | UK & Ireland
(4,463 Views)
Hi AdamB.
I found a way to do it based on the example you provided to me.
It was a great Help.
Thank you.
Gustavo Ramirez V.
Message Edited by GustavoRamirez on 11-10-2006 01:31 PM
(4,446 Views)
