Machine Vision
How to connect an FCB-IX47P to IMAQ 1411, there is no CN903
How to connect an "FCB-IX47P" to IMAQ 1411, As suggested by MarcoPolo, I did not find the connector CN903. The connectors I have found are the following: CN501, CN705, CN301, CN 802 and CN 805.
There is My camera is no a "A" series. Thanks for any more help.
Best regards
a.zaatri
(3,159 Views)
There is a connector CN301 with the Y Out on pin 4 this is luminance and C out on pin 2, this is chrominance. Each of these is coupled with a ground, the documentation is unclear on this. I would presume that the Y ground is pin 3 and the C ground pin 1. i would use this to connect to the S-Video connector on the 1411.
Hope that helps
Mike
(3,155 Views)
