Machine Vision
How do you grab images from mulitple channels
I have a PXI-1490 and want to grab images from multiple cameras and analyze the image to find the center of a tube.  How do you grab from mulitple cameras at the same time?
(2,974 Views)
Hi Steve,
Are you using LabVIEW to grab the images?  If so there is an example that will work with the PXI0-1409 that ships with LabVIEW.  It is called LL Scan Multiple Channels.  This VI acquires images from 4 different camera's.  What the example is doing is configuring a buffer for each of the channels.
I hope this helps.
Have a great day.
GG
(2,963 Views)
