03-31-2004 11:43 AM
04-01-2004 10:02 AM
04-01-2004 10:30 AM
04-02-2004 10:13 AM
03-19-2006 06:49 PM
03-20-2006 04:28 PM
03-20-2006 08:44 PM
03-21-2006
10:30 AM
- last edited on
11-14-2025
11:08 AM
by
Content Cleaner
Hi Suresh -
Particle morphology and analysis are performed on binary particles that result from performing a threshold operation on a grayscale image. (A compound threshold can be performed on each plane of a color image, too.) The threshold outputs a binary image, which can be "cleaned up" before analyzing the particles of interest.
One of the conveniences of binary image analysis is that the location of a particle is often irrelevant to whether it appears in the binary image. That is, if you use the proper thresholding technique, you should be able to pick out the particle you want in any part of the frame. Then, once you clean up your binary image, you can analyze the position, size, and other characteristics of the particle using the Particle Analysis step.
If you're unfamiliar with using the threshold operation for image analysis, I recommend some reading ![]()
Vision Concepts Manual, chp 16
found in C:\Program Files\National Instruments\Vision\Documentation
