04-06-2009 05:05 PM
I am trying to view a live image from a smart camera through VBAI on my PC using a labview VI. I'm trying to send an image from the smart camera to Labview because I could not achieve what I needed using only VBAI. I have VBAI 3.6, labview 8.5, NI 1744 Smart Camera
The VBAI ActiveX objects allow me to display an image in labview but I have not been able to find the right combination of property nodes to get the image into a format I can edit and use with the Vision Functions in Labview.
If you have any experience with this or know of more in-depth documentation than the following: "VBAI: ActiveX Component Reference Help" that would be extremely helpful. Thanks in advance,
04-07-2009 11:20 AM
Hi Poppie,
Is there a particular reason for your application that you cannot simply export the VBAI script to LabVIEW and do it directly?
