Machine Vision
How do I determine the execution bottleneck?
I have a four camera inspection system that I need to run faster. I want to find the bottleneck and look for ways to rearrange the processing work. In Vision Assistant there's a profile tool that tells me how quickly each vi executes. Is it possible to implement something similar on a fairly complex program?
(3,582 Views)
What environment are you in? If you're in LabVIEW, you can use the LabVIEW performance tools available in:
Tools --> Profile
There are four different tools in there - one of them is "Performance and Memory"
If you're working in Vision Builder AI (VBAI), then you should check out the VBAI help topic "Benchmarking Inspection Performance". The benchmarking tool described in that help topic is available in "Operate --> Benchmark Inspection"
Colden
(3,569 Views)
