02-04-2016 06:35 PM
New to NI Vision and Labview in general here.
How do I create a pause in my inspection so that I can change a setting on my DUT, then resume testing?
I want my inspection to run algorithms on two different image acquisitions, hence the pause to change my DUT settings. I thought the breakpoint was working well when I am in the configuration interface and I run the state, but it seems like when I run the inspection it skips over the breakpoint and continues onto the next inspection step without waiting.
Solved! Go to Solution.
02-04-2016 07:18 PM
could you send your vi?
for creating pause the best way is use flat sequence with 3 frame and put one while loop in second frame so until you do not press to make stop the while loop third part will not start
02-04-2016 08:28 PM
Are you running Vision Builder AI on Windows or on a remote target? If you have a remote target, which one?
On Windows, you can use a User Input step located in the last tab of the Vision Builder AI tools palette.
It will let you display a dialog that will pause the inspection until you click on a button.
02-04-2016 10:02 PM
