I have two suggestions for you:
1) You can use Ni Vision functions : writeattribute/readattribute in your code to set camera parameters.
2) you can send to your friend the file CAM0.IID (the file name depends on the interface name) from the folder C:\Programmi\National Instruments\NI-IMAQdx\Data (adjust the path depending on the drive letter and the driver you used - maybe NI-IMAQ for IEEE instead of NI IMAQdx). It should be copied in the same dir of the destination pc. I haven't tried it, but it should work.
Bye
Message Edited by simonerom on 06-15-2007 05:34 AM
Simone
