Machine Vision
How can to stitch image by program with using microsoft image composite editor ?
Hi,All
In my project I use three cameras to acquire images and  then stitch them to enchane the  system's  resolution(precision) because of the object is a bit large,I have used microsoft Image composite editor to stitch the images manually ,It works very well,but In my programm I must stitch images by code,I searched the internet to find how to program to stitch image by  microsoft Image composite editor but I didn't find the solution.Does anyone have used this tools to stitch images by program?could you give me some  directions?Thanks a lot!
Striving is without limit!
(4,029 Views)
Not familiar with the tool, here's similar post on it using Photoshop: http://forums.ni.com/t5/Machine-Vision/Image-stitching/m-p/860414
-Looks like it should be possible using LabVIEW Activex.
uday
(4,000 Views)
Thanks for your reply!in this post,the author mention that "Microsoft ICE has far away better image merging algorithm than Photoshop CS6",So,it's better if I can use Microsoft ICE  to do it.Smiley Happy
(3,995 Views)
In the same post it was mentioned you can try using ActiveX(http://forums.ni.com/t5/Machine-Vision/Image-stitching/m-p/2057336/highlight/true#M36053) to interface Image Composite Editor.
uday
(3,989 Views)
uday:
Thanks for your help,I have just  used potoshop cs6 to complete image stitching (call potoshop cs6  by LabVIEW ActiveX ),but it works not well.About microsoft image composite editor ,I have installed in my computer,but I found it didn't realize it's interface.It's method and attribute all shows IUnknown when I Open it's corresponding ActiveX Object Class.
(3,982 Views)
