Machine Vision
How can improve a “Geometric Pattern Matching”?
Hello everybody,
I post my question in this new thread, even if I found some resemblance with my problem in a previous one called “Pattern Matching Comparisonand in Pattern Matching Strategies” (tutorial document” .
I'm working on  a vision application with "poor an non uniform lighting" and "occlusion or overlapping parts". I'm using Labview 8.2 and with a GigE Dalsa M1020 camera. During my tests the camera supplier showed me how the Dalsa "Sapera LT" works. It seems that it works well, with a "edge based search". I could verify "as much well" because a couldn't compare it in parallel with NI Software, but actually this is not my problem, because I'm an NI developer and I want to find a solution with the NI platform.
With the same application I have to recognize very different objects (embossed plastic plate/label different in shape and color) situated on a belt conveyor.
When I started, I have based my program on "Pattern Matching" algorithm. It worked quite well with some objects, but with others the identification percentage was very (too) low, so I have modified my program introducing, also, "Geometric Pattern Matching" (different search based on the object type). Using this way the identification percentage is quite good, but I have that the program finds the exact pattern position but with a 180° rotated angle. This is a big problem for me because I have to pick the objects with a robotic arm and place its in a mould for successive working.
I guess to understand that this problem is related to the template image that doesn't contain enough features but I don't know what I have to do to improve my template image.
I attach some images and Vision Assistant script.
Does someone give me a suggestion to solve my problem?
Thank you in advance.
Best regards.
Michele
AUROS
Software e Tecnologie per Automazione
(3,728 Views)
Michele_R
Thanks for posting the images. Sorry to disappoint you but the ligting is very poor. The contrast (backgroud vs. Object) is also not helping. Is it possible to change the background to a color that is a bit lighter. Rememebr , proper illumination in Vision applications is very very important. I am wondering if you could use a color camera to get better results in terms of differentiating the background from the object under test. Take similar images using a color digital camera if you could and post it on the forum.
Other valid option is to try a 3D camera. http://www.sickivp.com/sickivp/applications/0/en.html
Good Luck.
(3,599 Views)
