Machine Vision
How can i combine three different color planes into a single color image?
Hi..
i have three different color planes, a red color plane 8 bits, a green color plane 8 bits and a blue color plane 8 bits. What i want to do is to combine this images to obtain the original color image. How can i do this withuot NI Vision? i only have NI IMAQ 2.6.
I guess it would be the same for when i have separate HSL palnes right?
(4,316 Views)
There is a VI in the Vision Development Module that will do this for you. How are you getting three eight bit images in the first place? Do you have a 1409 with three cameras or an RGB camera?
Regardless, I don't think you'll be able to do it with just NI-IMAQ. You'll probably have to convert each eight bit image into a 2D array of pixel values. concatenate each pixel with the other two to make a 24 bit value, and display the image using a picture control.
Good luck!
KyleV
(4,314 Views)
Hello Kyle,
Can I contact directly concerning an application similar to the one that you are talking about?
Best regards
Paulo Carmo
(4,114 Views)
Hello Paulo,
Thank you for using our discussion forums.  Since it has been three years, Kyle might not reply to this thread seeing as he might have already moved out of the department.  But to expand on what Kyle mentioned above, there are available VIs in VDM that you can use.  I am not sure what your application is, but you might want to take a look at IMAQ ArrayToColorImage, IMAQ ExtractColorPlanes, IMAQ ReplaceColorPlane, and IMAQ ColorValueToInteger.  If you would like to contact one of our applications engineers directly, you can also look into purchasing phone support or contacting your sales rep regarding a 30-day trial.  Hope this helps.
Vu D
(4,074 Views)
I´m triing to configure the 1409 and 4 Jai CV-A11 in frame delay readout and I already followed same exemples and doesn´t work, do I have the chence to have directly suport by NI?
Thanks in advance
(4,068 Views)
Paulo,
Here are two documents which can be found on our Developer Zone website which might be useful in regards to your setup.
http://zone.ni.com/devzone/cda/epd/p/id/4005
http://zone.ni.com/devzone/cda/tut/p/id/3526
If you would like to receive direct support from one of our applications engineers you can go to our Contact NI page from www.ni.com and request technical support.  You will need active service in order to use this medium of support.
http://sine.ni.com/apps/utf8/nicc.call_me
Take Care,
Vu D
(4,050 Views)
