Machine Vision
How can I release the memory allocated by ImageToArray? (ActiveX)
Using IDE: Borland C++ Builder 6 / BDS 2006
When I write the program with IMAQ ActiveX interface, I meet a problem in using ImageToArray function.
I can get the image data by this way:
Variant imgData;
Byte *pDataBuf;
int iBufSize;
imgData=CWIMAQ1->Images->Items(Variant(1))->ImageToArray();
memcpy(pDataBuf,imgData.ArrayLock(),iBufSize);
imgData.ArrayUnlock();
The problem is : after I called the codes many times, my program occupys almost all the memory.
So I wanna know: How can I release the memory allocated by ImageToArray ?
I know NI will not support BCB/BDS, but this is an ActiveX question, i thinkSmiley Tongue
sorry for my poor english!
(3,754 Views)
why no one help me?
帖子被YF_Jacky在09-26-2006 01:04 AM时编辑过了
(3,721 Views)
Hey YF_Jacky,
Have you tried calling "delete imgData"?  Let me know if that works for you.
Ryan F.
(3,680 Views)
thanks
unfortunately, "delete imgData" still can not solve the problem:mansad:
(3,582 Views)
Hey YF_Jacky,
I can't claim that I'm an expert with Active X and so I'm wondering what you're trying to accomplish with this line:
The examples I've seen using CWIMAQ1->Images have directly accessed the indexed image needed. Ex:
imgData=CWIMAQ1->Images(0)->ImageToArray();
(I have not tested this code so I'm not sure whether the pointer calls '->' or direct '.' function accessors are needed)
As far as I can tell the variable imgData should be released in memory as soon as it exits the scope of the program (I'm assuming that the imgData you've listed is a global variable).  Have you tried using a local variable for imgData?
Ryan F.
(3,567 Views)
