11-19-2008 02:09 PM
Solved! Go to Solution.
11-19-2008 04:09 PM - edited 11-19-2008 04:10 PM
PPM format is pretty easy.
Quick solution for reading may be like this:
Source in attachment.
May be you need to enhance this reader a little bit (for example, skip comment if present, width/height may present in separate lines, etc)
Andrey.
11-19-2008 04:32 PM
Andrey-
First of all, THANK YOU VERY MUCH!! I have been ripping my hair out trying to solve this problem. Second, can I get those files in 8.5 format? Thanks in advance.
A
11-19-2008 04:42 PM
Welcome! Here version 8.5
04-22-2009 11:44 PM
Dear Everyone,
I am using a PointGrey Chameleon camera,which is having some conflict on ni drivers,please explain the way i can use the same camera in LabVIEW.
Regards
Rajkumar
Development Engineer
04-24-2009 10:48 AM
Rajkumar,
If PointGrey provides a dll for the camera, this can be called in LabVIEW using a Call Library Function Node.
-Christina
