Machine Vision
How can I change the sequence of images I imported into Vision Assistant?
I have several large folders of images I pulled from a framegrabber. Each has between 300-500 .bmp images which are named 0, 1, 2, 3, ... , 365.  The problem is that when I use Vision Assistant to open the images it opens them out of order.  Ex: 1, 10, 100, 101, 102, ..., 11, 110, 111, ..., 12, 120, 121, ...
What is even more frustrating is that there doesn't seem to be a way to reorder the pictures, nor do I think I want to spend the time to do this for the 16 folders of images I am working with.
Thoughts... Ideas?
(3,414 Views)
Accepted by topic author WuTang4eva
In cases like these, it is best to name the images using 3 digits and padding with zeroes on the left.
It would be pretty simple to write a quick vi that would read all the files in a directory.  For each file, it would strip out the old number and replace it with the three digit version.  If the number is less than 100, it could rename the file automatically.
I can't think of any other ways to solve your problem.
Bruce
Bruce Ammons
Ammons Engineering
(3,410 Views)
