I think you left out a very important part in your version.
Action (Interface, Digital) {
AcquisitionWindow (0, 1, 320, 240)
MaxImageSize (320, 246)
You didn't include the AcquisitionWindow command, which tells IMAQ what size of image to expect. I noticed you set it earlier in the file, but I think it needs to be set here.
If you don't set things in the right order, the camera will default to the standard settings, which is probably why you aren't getting higher frame rates.
My icd file was written for IMAQ 2.5.1 or so, and there have been a number of changes since then. You might want to try loading an older version of IMAQ and see if my file works.
Bruce
Bruce Ammons
Ammons Engineering
