Machine Vision
Help with my Camera!
@Abook7 wrote:
Andrey, Do you know how to change the dimensions to mm^2?( what are the current dimensions?)
You need to calibrate your image to Real World coordinates. Set Simple Calibration should be enough
@Abook7 wrote:
and how to see image out?
Not fully understand your question. Just connect Vision Dsplay to Image Out.
Abook7 wrote:
can I see what are the objects its identifing?
When Show Center / Show Bounding Box are active - then it should be visible like here.
Andrey.
Message 11 of 11
(669 Views)
