Machine Vision
Help needed in compiling a .SCR file to VI and C program
Hi all!
I am a student using evaluation version of NI Vision assistant 8.6. I have a script file that i want to convert to VI. As you know we cannot do it on a evaluation version. I neither can afford the package right now. Please help me convert the file to VI and C code.
Please mail me on snapy050@gmail.com
Will be very thankful if some one generously helps.
Snapy
(3,596 Views)
You can use the Express VI instead (palette Vision and Motion>>Vision Express once you install the Vision Development Module). The Express VI will launch Vision Assistant in a Wizard mode. This still allows you to use Vision Assistant to create your Vision algorithm, and it will generate the LabVIEW code when you return to LabVIEW. You can view the code generated by right-clicking on the Express VI and select Open Front Panel.
Note that the code generated is also licensed and that it will work for 30 days from the day you install the Vision Development module.
If you want to keep using the Vision VIs after that, you'll need to purchase a license and activate the software. Which university do you work with? Ask around, I am sure you can probably find a professor who has a license for it.
Hope this helps,
-Christophe
(3,581 Views)
Snapy -
As a student, you can purchase the LabVIEW Student Edition Software Suite DVD at a student discount.  The LabVIEW Student Edition Software Suite consists of the following National Instruments software (listed below) on a single DVD.  Starting the 1st week of December, NI will start shipping LabVIEW 8.6 Student Edition.
  • LabVIEW 8.5 Student Edition for Windows Vista/2000/XP
  • LabVIEW Digital Filter Design Toolkit
  • Modulation Toolkit for LabVIEW
  • LabVIEW Control Design and Simulation Module
  • LabVIEW System Identification Toolkit
  • LabVIEW SignalExpress
  • NI Circuit Design Suite (Evaluation)
  • NI Vision Builder Development Module
  • NI Vision Builder for Automated Inspection
  • NI Vision Acquisition Software
  • NI Device Drivers
For additional information:
Order Student Software through Academic Superstore
Mark Walters
(3,566 Views)
