Machine Vision
Help Required For Surface Inspection
   I have to inspect surface of the piston,for defect like,crack,spot, please help me to select appropriate camera and light ,please find attached photograph of the piston
Warm Regards
Orooj Ahmed
(3,459 Views)
I having the privilage of developing a machine vision system for piston inspection would like you to take into account the following
1. The surface will be oily and will not look so shiny (go for a low angle diffused lighting).
2. Is there any measurement involved? Then you have to use a lot of indirect measurements.
 3.Dont go for a line scan camera (remember you are going to kill mechanical guys happiness)
The first and foremost point is how time have you got to inspect a piston?
(3,355 Views)
