Machine Vision
Hardware Selection Step-motor Control
Hi
If I choose U3-HV (-10V to +20V), is it better for A4988?
Regards
Message 11 of 18
(3,149 Views)
Hi
I spoke with the company, selling the driver A4988. The voltage of all pins is 3.3 - 5V and the current is up to 10mA.
Regards
Message 12 of 18
(3,136 Views)
See Sections 2.5 and 2.6 of the U3 User's Guide.  The U3-LV has 16 flexible inputs that can be digital input, digital output, timers (2 max), counters (2 max), or low-voltage (0-3.6V max) analog inputs.  The difference with the -HV compared to -LV is that the first 4 flexible inputs are changed to fixed +/-10V analog inputs.  From what you have described about your application, you just need 1 or 2 timers to create output pulses, so you can use the LV or HV.  Most people buy the HV because it has the +/-10V inputs and still has 12 flexible I/O.
As for other devices from LabJack, the U6 would be a USB-only device with higher quality analog inputs.  The T7 has the same high-quality analog inputs, and provides USB, Ethernet, and even WiF on the -Pro version.
Message 13 of 18
(3,136 Views)
 The A4988 datasheet says that the logic supply range VDD is 3.0-5.5V and draws 8mA max.  It then says that a logic input high is VDDx0.7, so if VDD=5.0 then a logic high is only guaranteed if the pin is driven to 3.5V.  It would probably work with 3.3, but is not guaranteed.  To make sure it is happy, I suggest you use DAC0 set to 4.0V to supply VDD as described in Message 9 earlier.
Message 14 of 18
(3,129 Views)
Hi
Thank you for your answer. Finally I will choose U3-HV-OEM. Is it possible to set 4.0V to DAC0 as described in Message 9 earlier.
Regards
Message 15 of 18
(3,122 Views)
Hi
What do you think about arduino. What kind of arduino is suitable for control of A4988.
Regards
Message 16 of 18
(3,112 Views)
I use the Pololu - Tic T834 USB Multi-Interface Stepper Motor Controller  Family of controllers and use the USB interface.  You can set individual commands through a CMD line, through LabVIEW.
Message 17 of 18
(585 Views)
I've also used myRIO with A4988 stepper driver before, it works!  See this video: https://www.youtube.com/watch?v=pdbDDZlHsr0
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
Message 18 of 18
(537 Views)
