Machine Vision
HELP: Error when using IMAQ USB
I am a new user. To learn vision acquisition software, I firstly installed "LabVIEW 2012", and then installed "Vision Acquisition Software", and then "Vision Development Module", and finally "NI-IMAQ for USB Cameras". I can see "IMAQ USB" under the "vision and motion" button. But when I run the programme, there is always error indicating as: Call Library Function Node: Library not found or failed to load.
Can you give me some suggestions? Thank you in advance!
(3,912 Views)
could you explain more what is your means do you have any image of your vi and related error ?
(3,901 Views)
IMAQ for USB Cameras is a very old program.  It was merged into Vision Acquisition Software a while ago.  Installing the old software on top of the new software probably corrupted something.
I would uninstall IMAQ for USB, then reinstall Vision Acquisition.  Hopefully that will fix the problem.
Bruce
Bruce Ammons
Ammons Engineering
(3,898 Views)
(3,884 Views)
Then it is another error
(3,882 Views)
