Machine Vision
Golden Template VI result show black
Hi ,all
       I read the Golden Template inspection VI's code from examples. I modified a few of code from it. But I found that VI my modified can't do the same to the Golden Template inspection VI. In the Golden Template inspection VI,the defects show green and red colors. In my VI,the defects show black color.
       Do any one can explain this? Any advises is welcome.
       attechments is my VI and image,you can see my code and find my error.Please point it out .thank you!
(3,234 Views)
I get this
!   F:\nii\image.zip: Unexpected end of archive
!   F:\nii\image.zip: The archive is either in unknown format or damaged
Also can you attach the vi for lv 8.0?
(3,232 Views)
Thank you for you reply. I had resolve this problem.It need to open the image indicater's plette to user defined.
(3,224 Views)
