Machine Vision
GigE vision on NI cRIO-9068
Hey Eric,
Does GigE work with the cRIO 9081 or 9082 chassis?  Those are a little more expensive, but might be a good option.  They have a lot more processing power.
Bruce
Bruce Ammons
Ammons Engineering
Message 11 of 22
(4,073 Views)
Hello Bruce:
Yes, the cRIO 908x chassis do support GigE. However they cost almost twice from the cRIO-9068, and the project is a bit constrained in budget, that is why we were looking for alternatives.
Robst - CLD
Using LabVIEW since version 7.0
Message 12 of 22
(4,069 Views)
Well, that is good to know.  I am thinking about doing a future project with the 9081 chassis, and knowing GigE vision works is a key detail.  I probably knew that when I was looking at that project, but couldn't remember.
If you want an FPGA available for image processing, the 908x chassis might be your best option.  If you don't really need the FPGA processing, I would probably pick the EVS.
Bruce
Bruce Ammons
Ammons Engineering
Message 13 of 22
(4,068 Views)
I know this is an old post ,Still...... I am having a GIGE camera and cRIO 9082. But I cannot see the camera in  Max. Do anyone know how to fix this?
Message 14 of 22
(3,566 Views)
Did you install IMAQdx and GigE Vision support to the target?
Did you enable the secondary Ethernet port for TCP/IP (assuming that is where the camera is connected)?
Does the IP configuration of the camera and 9082 secondary port match (usually setting both to DHCP/LinkLocal is best/easiest)?
Message 15 of 22
(3,557 Views)
Hi BlueCheese,
I have installed IMAQdx RT , Vision RT in cRIO. I am not sure how to install GIGE support.(How to?)
How do I check if I have enabled TCP/IP in second port?
Yes, both IPs match- 192.28.10.12 and 192.28.10.11 (though configured in static rather than DHCP).
Message 16 of 22
(3,543 Views)
Sorry, TCP/IP is enabled . I forgot to note it.
Message 17 of 22
(3,537 Views)
BlueCheese ,
Any ideas? I am still stuck up
Message 18 of 22
(3,514 Views)
Can you show a list of software you have installed to the cRIO? Under the NI-IMAQdx component there is an optional piece for GigE Vision that must be installed.
Message 19 of 22
(3,510 Views)
Here is the list of inistalled softwares
Message 20 of 22
(3,507 Views)
